Editorial: Whose Back Yard?
June 29, 2009
In the case of obsolete computers, TV sets, cell phones and myriad other electronic products discarded for recycling and reclamation, the challenge of how to safely dispose of them has become a major NIMBY issue.
Leading Lean: Solve the Right Problem
June 29, 2009
Before you start down a path, make sure you’re setting off on the correct journey.
Assembly in Action: Coiled Spring Pins Improve Steering Column Assembly
June 29, 2009
The fasteners help isolate the assemblies in which they are installed from shock loads and vibration.
Robotics Notebook: Robotic Cells Keep Ohio Firm Competitive
May 28, 2009
Despite the current economic downturn, G&W has been able to remain both profitable and competitive. Not only that, the company is well positioned to grow all the faster when the economy gets back on its feet again.
Assembly In Action: Snap-Ring Installer Cuts Processing Times
May 28, 2009
The General Electric Aviation plant in Durham, NC, assembles a number of jet engine types, including those in GE’s GE90 and CF34 product lines, for use in a variety of commercial and military aircraft.
Assembly In Action: Kits Ensure Correct Fastener Selection
May 28, 2009
As is the case with Airbus’ original A320 plant in Hamburg, Germany, AFS supplies the Chinese plant with all the fasteners used in the plant’s fuselage and wing joint area.
Bonding Lines: Belt and Suspenders
Dr. George W. Ritter
May 20, 2009
Weldbonding combines adhesive bonding and welding into one process step.
Quality in Assembly: Problem-Solving System Helps Cabinet Maker Win
May 20, 2009
A strand of ribbon isn’t much, but for one Michigan assembler, it may just have led to a 2008 Shingo Prize for Operational Excellence.
Assembly In Action: Plastic Welders Take to the Sea
May 20, 2009
To build each hull, Turbotsan’s operators first create a frame of polyethylene pipe that serves as the skeleton for the boat-much like the “ribs” in a traditional wooden hull.
We Fed It: Bowl Feeds Handles for Dental Mirror Assembly
May 20, 2009
Five inches long and 0.5 inch in diameter, the mirror handle was shaped for ergonomics and utility-not for automated assembly.
Previous 1 2 … 115 116 117 118 119 120 121 122 123 … 222 223 Next
