Assembly in Action: Multichip Bonder Assembles Flip Chips
June 1, 2003
Amkor Technology Inc. needed a multichip die bonder to assemble large flip chip devices for semiconductor manufacturers. It selected Datacon North America Inc.’s 2200 apm + multichip die bonder.
Assembly in Action: Adhesive Helps Endoscopy System Perform
June 1, 2003
Given Imaging contracted Scapa Medical to devise a way for reusable antennas to be placed onto the patient's skin and then be removed after 8 hours, without damaging the antenna or hurting the patient.
Uncommon Sense: Cells Aren’t a Panacea
June 1, 2003
With the right mix of parts, processes, people and planning, cells can produce exciting results. But it doesn’t always work out that way.
Assembly in Action: Dispensing System Ensures Mixing Ratios for Foam Padding
June 1, 2003
Brock contacted Fluid Research Corp. for dispensing equipment to mix its foam bead technology.
Assembly in Action: Manufacturer Cuts Process Time With Adhesive Dispensers
June 1, 2003
Helwig Carbon Products Inc. uses EFD's Ultrasaver dispenser to apply adhesive to assemble carbon brushes.
Assembly in Action: Yachts Sail to Victory With Adhesive
June 1, 2003
To fabricate its Sinergia 40 racing yachts, Sinergia Composites relies on Vantico's Araldite 2022 methacrylate adhesives.
Assembly in Action: Manufacturing Cell Doubles Efficiency
May 20, 2003
At the beginning of 2002, Cincinnati Test Systems Inc. (Cleves, OH) had an onslaught of orders for different kinds of instruments.
Assembly in Action: Precision Press Assembles Self-Aligning Bearings
May 20, 2003
Spyraflo Inc. (Peachtree City, GA) manufactures specialty bearings that offer innovative ways for original equipment manufacturers and fabricators to reduce cost and enhance bearing performance.
Assembly in Action: Solenoid Withstands Chemicals and Cuts Costs
May 20, 2003
Liquids can wreak havoc on electrical components. But thanks to a good coil form design, controlled molding conditions, and the use of the same material for the bobbin and outer shell, an encapsulated solenoid has been created that resists liquid penetration.
Uncommon Sense: Get in Front! Stay There!
May 20, 2003
Once you have the lead, the only way a competitor can catch you—or pass you—is if you stand still.
Previous 1 2 … 191 192 193 194 195 196 197 198 199 … 222 223 Next
workstation
