Down the Line: Smart Adhesive Has an On-off Switch
March 1, 2003
Two scientists at Lehigh University (Bethlehem, PA) have developed a polymer-aluminum interface whose adhesion strength can be controlled by temperature.
Assembly in Action: Press Helps Supplier Latch Onto Success
March 1, 2003
Orbital riveting is used to assemble the latches that control the motion of the back of a car seat. This may seem like an easy process, but appearances can be deceiving.
Down the Line: Hands Across the Water
March 1, 2003
The first successful transatlantic telegraph cable, completed in 1858, was one of the defining moments of the 19th century.
Down the Line: Smart Furniture Eases Assembly Frustration
March 1, 2003
The often-frustrating task of assembling build-it-yourself furniture, such as bookshelves, may soon become much easier.
Assembly in Action: Plastic Cuts Cost of Motorcycle Engines
March 1, 2003
In 1946, Piaggio SpA (Pontedera, Italy) created the world’s first mass-produced scooter, the Vespa. Almost 60 years later, the Vespa—and Piaggio—are still going strong and adapting with the times.
Down the Line: Printers Swing Into Mass Production
March 1, 2003
Ink-jet printers will mature into automated manufacturing machines to mass-produce fully functional toys, radios and other devices if a research program at the University of California (Berkeley, CA) is successful.
Assembly in Action: Dispensers Improve PCB Quality
February 1, 2003
Sanyo Electric Co. Ltd., a supplier of electronic components for the personal telecommunications market, recently purchased two Asymtek (Carlsbad, CA) Millennium M-620 dispensing systems to equip its printed circuit board (PCB) facility in Osaka, Japan.
Uncommon Sense: The “Best Practices” Hoax
February 1, 2003
Best practice is situation-specific. Use your intellect, talent, and imagination to create a real best practice that matches your needs!
X-Y-Z: Cups Handle Variety of Parts
February 1, 2003
Vacuum cups are the simplest and least expensive method of gripping parts.
Assembly in Action: Robots Help Assemble Fiber Optic Pigtails
February 1, 2003
Manually assembling fiber optic pigtails requires operators to work with tiny parts that have submicron tolerances.
Previous 1 2 … 195 196 197 198 199 200 201 202 203 … 222 223 Next
workstation
