COLOGNE, Germany—A team of students from the Munich University of Applied Sciences has developed a 3D printer with drylin linear units from igus GmbH that can cost-effectively produce structural parts in space.
Pressure-sensitive adhesives (PSAs) offer numerous advantages for aerospace assembly. PSAs enable assembly of dissimilar materials with a continuous bond area.
MIRABEL, Quebec—Airbus is working to repurpose part of an aircraft assembly plant here that has been vacant since Bombardier ended production of the CRJ passenger jet.
Last month, NASA's Mars Perseverance rover landed on the red planet after 5.5 months of traveling through space. The rover's primary mission is to search for signs of ancient microscopic life and collect the first ever Martian soil samples for analysis.
After a nearly 20-year hiatus, supersonic passenger travel is about to make a comeback. One of the companies leading the charge is Boom Supersonic Inc.
Self-pierce riveting (SPR) is a cold joining process for fastening two or more sheets of material by driving a rivet through the top sheets and upsetting it, under the influence of a die, into the bottom sheet without breaking through it.
Many types of welding are used in manufacturing. Some, like gas metal arc, laser and ultrasonic, are quite well-known, while others are less popular but a perfect fit for a specific application.
FRONT ROYAL, VA—Silent Falcon UAS Technologies, an unmanned aircraft manufacturer, plans to establish an East Coast headquarters here at the Front Royal-Warren County Airport.
