Adhesives & Dispensing AssemblyScrewdriving and Riveting Assembly
New and Noteworthy
New Fastening Technologies Improve Flexibility and Throughput
By JJ Moore
Illustration of an automated adhesive dispensing system applying sealant to a component for precision bonding and electronics assembly.
Source: DELO Industrial Adhesives
June 26, 2026
As manufacturers push for lighter designs, faster cycle times and more reliable joints, new fastening technologies are helping simplify assembly while improving performance. From aerospace fasteners to automated fastening systems and lightweight inserts, these products are enabling greater flexibility, improved quality and more efficient production.
Fastening System Supports Lightweight Aerospace Assembly
Böllhoff and DELO have combined fastening and adhesive technologies to create a lightweight joining system for aerospace interiors. The system pairs Böllhoff’s ONSERT fastening element with DELO’s light-curing adhesive to enable bonding without drilling or weakening materials, making it suitable for applications such as cable holders on lightweight components.
The adhesive cures within seconds and delivers high strength while maintaining flexibility, supporting automated, high-volume production. The process also meets aerospace fire, smoke and environmental requirements and operates across a wide temperature range.
www.delo-adhesives.com
Böllhoff Group
www.boellhoff.com
Source: Industrial Rivet & Fastener Co.
Blind Fasteners Provide Flexible, Low-Cost Assembly Option
Industrial Rivet & Fastener Co. offers the RivetKing JK Series jack nut, a blind fastener designed for non-load-bearing applications in thin materials such as plastics, paperboard and light metals. The fastener collapses on the blind side to form a secure grip, providing a simple and cost-effective installation method.
Available in sizes from 8-32 to 1/2-13 and M4 to M12, the fasteners support grip ranges from 0.01 to 0.35 inch, with head diameters between 0.469 and 0.625 inch. They are easy to install and adaptable to a variety of assembly applications, including situations where access is limited.
https://rivet.com
Source: SPIROL
Aluminum Inserts Improve Performance in Plastic Assemblies
SPIROL has introduced aluminum threaded inserts designed for heat or ultrasonic installation into plastic components. The Series INS19, INS20, INS29 and INS30 expand SPIROL’s threaded insert offering and complement the existing brass product line. The additions complete the company’s aluminum insert portfolio, covering molded-in, press-in and heat or ultrasonic installation methods. Heat and ultrasonic installation methods allow surrounding material to flow into undercuts and knurls, improving torque resistance and pull-out strength compared to press-in inserts.
The aluminum design reduces weight while maintaining strength and supporting environmental requirements. The inserts are intended to simplify assembly, improve joint integrity and support lightweight product designs.
SPIROL
www.spirol.com
Source: Visumatic
Automatic Nut Driving Systems Reduce Errors and Improve Throughput
Visumatic has introduced a range of automatic nut driving systems designed to improve fastening accuracy and reduce cross-threading. The systems feature automated feeding and positioning, with built-in monitoring to ensure consistent installation.
The VNR-800 handheld nut driving system improves operator ergonomics and throughput with self-aligning socket technology. The VNPM automatic nut driver system is designed for robotic applications, delivering high-speed nut feeding and driving for consistent joint control. The VNPD automatic nut driver system is designed for easy integration into assembly equipment, offering compact construction, durable components and low-maintenance operation for long-term reliability.
Designed for both robotic and handheld applications, the systems support a wide range of fastener types and configurations while reducing operator handling.
Visumatic
www.visumatic.com
KEYWORDS: automatic screwdriving blind riveting threaded inserts
Jj moore author
  • Lean + Flexibility = Throughput
  • new assembly tools
    New Fastening Tools Improve Ergonomics, Throughput
  • fastening technology
    New Fastening Technology Improves Ergonomics, Throughput
  • March 10, 2026
