TechnologiesNew ProductsTest and Inspection Assembly
New & Noteworthy
Software Turns Cameras Into GigE Vision GenICam Devices
Pleora's eBUS Edge GigE Vision software transmitter
Image courtesy of Pleora Technologies
September 17, 2024
Pleora Technologies is expanding its eBUS Edge GigE Vision software transmitter with feature-based licensing tiers to help designers meet performance and cost demands as new 3D cameras, sensor-based imaging devices, and embedded and IoT products are deployed in machine vision applications.
The software converts cameras and embedded devices to fully compliant GigE Vision GenICam devices without investing in any additional hardware. By adding eBUS Edge to a CPU’s software stack, devices support GigE Vision compliant image transmission, can respond to control requests from a host PC, and integrate with off-the-shelf machine vision processing. The software has already been designed into several applications, including 3D and smart cameras and data transmission systems for medical imaging.
Feature-based licensing tiers for eBUS Edge support multipart, multi-stream 3D, 2D and 1D performance requirements for high-value imaging and sensor platforms and single-stream 2D and 1D transmission for price-sensitive cameras, embedded platforms, and IoT devices. The software is designed for both Intel and ARM architectures and is compatible with all sensor and camera types.
For 3D inspection, eBUS Edge converts 3D images and data into GigE Vision and GenICam compliant time-stamped data that is transmitted with associated metadata over low-latency Ethernet cabling. Data from multiple sensors, including 1D and 2D images, can be synchronized and transported in parallel using multiple streams. To simplify image processing, the 3D data is received, analyzed and displayed using off-the-shelf machine vision processing.
For embedded applications, eBUS Edge enables designers to develop small form-factor GigE Vision imaging and sensor devices that are easily networked and integrated with machine vision processing solutions. In these multi-sensor applications, embedded processing can make local decisions, transmit processed data to other sensors or standard vision processing technology, and respond to control requests from a host controller over a low latency GigE Vision Ethernet connection.
Pleora Technologies
www.pleora.com
KEYWORDS: machine vision systems
  • GigeVision interface standard
    A3 Releases GigE Vision 3.0, Opening New Possibilities in Machine Vision
  • Pleora GigE vision interface
    GigE Vision Embedded Interface Transmits Video, Data in High-Performance Applications
  • 2020 jan assembly
    ASSEMBLY January 2020 Issue
  • Kokusai Denki Electric America
    Kokusai Denki Electric America has been selling video cameras in the USA for over 50 years. Based in Tokyo, Japan the company makes monochrome and color cameras that use one or three sensors and provides outputs for Composite Video, HD-SDI, Camera Link and GigE up to 5GigE.
