TechnologiesNew ProductsTest and Inspection Assembly
New & Noteworthy
Vision Light With Hidden Strobe
Smart Vision Lights RHI200-DO Lightgistics series light
Image courtesy of Smart Vision Lights
September 20, 2024
The RHI200-DO Lightgistics series light features 64 LEDs in a 205 by 205-millimeter ring for intense uniform lighting at long working distances of up to 2,000 millimeters. Equipped with hidden strobe technology, the light delivers all the advantages of strobing without the disturbance and disorientation often linked to LED strobe lights.
The light specifically addresses the challenges of accurate, high-speed bar code reading and optical character recognition (OCR) on highly reflective plastic wraps and shipping bags. Dual OverDrive technology allow engineers to easily attach polarizers that maximize light output in high-speed conveyor systems.
The light’s integrated camera mount fits most common machine vision cameras, and the light can be directly connected and controlled through a camera’s trigger output. The light’s onboard charging capacitors ensure powerful bursts of energy while maintaining a low consistent electrical draw. The IP65-rated light operates at working distances of 500 to 2,000 millimeters.
Smart Vision Lights
smartvisionlights.com
KEYWORDS: machine vision systems
  • Plastics Assembly: Welding With Light
  • Welding Tailights With Light Beams
  • What’s New With Machine Vision Systems
  • Designing with Plastics
  • August 13, 2026
    The Hidden Waste Inside Lean Manufacturing
    In this webinar, Dr. Terra Vanzant Stern will explore how manufacturers can rethink long-standing approaches, identify waste within Lean itself, and leverage modern tools and strategies to achieve stronger operational results.
