We Fed It: Bowl Provides Ideal Solution
April 29, 2010
Homer City Automation built a vibratory bowl and track to feed tips for medicine droppers.
Signature Analysis Beyond Press Force
April 29, 2010
The basic concept of press-force monitoring has evolved into two branches. One focuses on pressing applications, but offers assemblers more flexibility and precision when capturing information about the force-distance curve. The other branch, called signature analysis, lets assemblers apply the monitoring concept to applications beyond press force.
Automation Profiles: This Assembly System Has the ‘Write' Stuff
April 29, 2010
Systems integrator Orientech Inc. recently designed an automated assembly system for surgical pens. The system assembles pens at a rate of 120 per minute.
The Editorial: A Speed Bump on the Road to Green
April 29, 2010
In our attempt to free ourselves from dependence on Middle Eastern oil, we may very well have become just as dependent on Chinese mineral deposits.
Small Robots Deliver Big Results
April 29, 2010
Traditionally, robots have required a large footprint and a big pocketbook. However, a new breed of lightweight, benchtop machines provide big performance in a small package. Mini robots offer a cost-effective way to handle and assemble small parts, especially when space is scarce.
Assembly Automation: The Trouble With Springs
April 29, 2010
Springs are often a very inexpensive component in an assembly. However, the problems created in detangling and handling them can greatly affect the productivity and efficiency of automated assembly systems.
Fastening Threads: More Data, Less Knowledge?
David Archer
April 29, 2010
Just as both the quality of the joint and the quality of the joint designer’s knowledge base will be limited by reliance on numerical analysis, the same limitations occur when experience and applied experimentation is all one has to draw from.
Time's Running Out - Nominate Your Assembly Plant Today!
April 14, 2010
We're looking for a few good plants. Click below to nominate your plant for the 2010 Assembly Plant of the Year award.
Wire Processing: Automating Harness Assembly
April 1, 2010
Inserting wires into connectors and bundling them into harnesses has always been done manually-until now.
Assembly In Action: Mobile Workstation Increases Efficiency
March 29, 2010
Hol-Mac wanted to increase technician efficiency in its plants by making test equipment and computers more mobile. This mobility would let technicians bring equipment to areas throughout the four facilities as needed, rather then walking back and forth endlessly to static workstations.
Previous 1 2 … 109 110 111 112 113 114 115 116 117 … 286 287 Next
