A rod end bearing, also known as a heim joint or rose joint, is a mechanical articulating joint. Originally used in aircraft, these bearings can be found in cars, trucks, lawn tractors, boats, industrial machines and other applications. This article explains how they work and how to specify them.
This article compares the myriad ways to mark wire, including labeling, hot stamping, ink-jetting and lasers. What are the benefits and limitations of each technology? When would one technology be used over another? This article provides the answers.
Autoliv has been manufacturing seat belts since 1956, and was first in the world with three-point belts in 1959. Nevertheless, Autoliv recently faced a new challenge related to its seat belts.
Saia
Burgess, a manufacturer of motion control components, recently implemented
lean-manufacturing initiatives at the warehouse of its Vandalia, OH, manufacturing
facility. To “lean” the order completion process, Saia Burgess has replaced the stockroom
shelving with four horizontal carousels that are integrated with
pick-to-light technology.
The second generation of Ford SYNC was recently
introduced and appears on 2010 model year vehicles. Ford
uses the MMTS Moving Video Test System from VI Technology to perform functional
tests on the SYNC system’s electronic components.
Northrop
Grumman Corp. has been one of the largest suppliers to the U.S. military for
many years. Recently, the company sought a way to achieve higher accuracies on large-volume
machine tools used to produce the F-35 Joint Strike Fighter.
Automaker PSA Peugeot Citroën faced two
challenges when welding the body of the Peugeot 3008, which is made at its
assembly plant Sochaux, France. It wanted to achieve high body stiffness and
develop new design options.
