Manufacturers vigorously seek out best practices because they can improve metrics, such as stock price, sales and profitability. There’s only one problem: Best practices are the actions that solved yesterday’s problems.
Recently introduced USB3 Vision joins several other established standards, all of which increase component selection, simplify setup and expand the market for vision systems.
Component interoperability for PC-based vision systems has come a long way in a short time. The main reason for this quick evolution is interface standards, which the AIA, a machine vision trade group, began introducing in 2000.
Producers of plastic, rubber and composites use Dynisco Inc. melt-pressure and temperature sensors, controls, and analytical instruments to maximize manufacturing efficiency and productivity. Dynisco has served these customers well for more than 50 years, providing leading-edge technology manufactured to ISO 9000 quality standards.
Fabricating and testing optical components is a very detailed process. It begins by grinding a spherical glass blank using ring tools to create a semifinished lens. Next, the lens’ rough surface is rotated and rubbed against a tool having the desired surface shape.
Aircraft Technologies Inc. makes sinks, toilets and other assemblies for airframe manufacturers, completion centers, and maintenance and repair facilities.
On May 22, 2012, after eight years of preparation, Space Exploration Technologies (better known as SpaceX) launched the Dragon spacecraft atop a Falcon 9 rocket from Cape Canaveral Air Force Station in Florida. The spacecraft traveled more than 200 miles to reach its destination: the International Space Station (ISS).
After writing this column for six years, I understand the need for brevity. With that in mind, I thought it would be useful to summarize some of the key points that I’ve raised in the past.
I have included the issue in which each column appeared so you can delve into the topic in more detail if desired. As always, please feel free to contact me with your questions, comments or observations.
Wire and cable insulation is typically made from thermoplastics, thermosets or fibrous coatings such as fiberglass and fiber-braiding. Unfortunately for manufacturers, inks and coatings do not print or bond well to most of these materials when using standard techniques.
A fully automatic stripping and crimping system might be the “glamour” technology of wire harness assembly shops. However, there’s still plenty of work for handheld electric, pneumatic and manually powered crimping tools.
