Home » Topics » Industries
Industries RSS Feed RSS
Attractive Bonding for Aesthetic Assembly
August 1, 2010
Most common cosmetic defects can be avoided with attractive welding techniques.
Software: Cost Modeling
August 31, 2009
Cost modeling is the practice of understanding the cost structure of the products purchased or manufactured for the purpose of optimizing a design or supply chain. The cost modeling process is focused on supporting three business areas: target costing, procurement, and competitive analysis.
Joining: Double Duty
July 27, 2009
Aerospace and automotive manufacturers have been incorporating hybrid joining into their production for years now. This joining method, however, has been largely ignored by appliance manufacturers. A novel approach to assembly construction, the method is surely applicable within the appliance industry - and stands to benefit both appliance manufacturers and end users.
Controls & Sensors: Vapor Sensing
January 30, 2009
Residential gas water heaters have long been considered safe when properly used. Yet the potential dangers resulting from the improper use and storage of gasoline and other flammable materials in the vicinity of the water heater have continued to be a concern among manufacturers of residential gas water heaters.
Joining: Think Zink
January 31, 2008
Molten zinc alloy is not commonly considered as an instant curing “glue,” nor as an alternative to instant-cure adhesives for bonding small components. But it has been used for more than 60 years in FisherTech’s Injected Metal Assembly (IMA) process to join components in much the same way as adhesives. While zinc alloy can’t replace adhesives in all applications, it can do so in many assemblies without the problems of peeling and thermal degradation inherent with conventional adhesives, and without the need for special surface preparation.
Joining: Failsafe Fusing
Chookazian Steven M.
August 1, 2007
There are many critical plastic-part assembly applications where the long-term integrity of the joint is absolutely essential, such as when the assembly must contain a liquid. Examples include various small household appliances, oral hygiene appliances, or parts for major appliances, such as a dishwasher arm or clothes washer pump assembly.
Joining: Better Bonding
February 1, 2007
Combining materials of choice is important for the appliance industry where “form follows function” is archetypal. Appearance, performance, cost, and assembly ease constantly dog the engineering community in this industry. This is particularly true when joining dissimilar materials, such as metals and plastics, into one unit or subassembly.
JOINING: Pivotal Point
August 1, 2006
When an application requires two thin metal sheets to be joined permanently face-to-face, designers routinely have turned to rivets, welding, or adhesives and tapes. But tradeoffs loom with each of these methods. An innovative fastener design using clinch technology provides a more practical and less complicated joining method that is able to perform multiple functions and expand design possibilities.
SWITCHES & RELAYS: Cut the Chatter
August 1, 2006
Recent developments in electronic equipment have led to technically advanced appliances that require progressive electronic technologies.
JOINING: Forming a Circle
February 1, 2006
Edge-forming rollers join round assemblies.
Tubing, cylindrical housings, and similar shapes often pose joining challenges. Crimping and pressing operations have been frequently used to form an edge on such shapes as a means of joining them to another part or to enclose an assembly of parts, but those methods have their drawbacks.
Previous 1 2 … 151 152 153 154 155 156 157 158 159 Next
