Assembly in Action: Filtration Systems Cut Operating Costs
June 2, 2008
Established in 1989, Michigan Automotive Compressor maintains a 786,000-square-foot produc-tion facility equipped with some 200 robots and 650 production machines.
Assembly in Action: Meter Mix System Encapsulates Connectors
June 2, 2008
To protect one of its under-the-hood automotive connectors, the company needed to encapsulate some 80 wires that allow the plug-in device to tie together an onboard computer network.
Assembly in Action: Conveyor Maximizes Space Usage, Efficiency
June 2, 2008
Ophthonix wanted a system that would be easily scalable so that it could adjust to future production needs.
Quality in Assembly: X-rays Reveal Hidden Flaws
May 16, 2008
X-rays are used to inspect everything from golf clubs to artillery shells.
Leading Lean: Those Darn Corporate Guys
May 16, 2008
A lean transformation requires striking a difficult balance between leveraging the efforts of the whole organization and enabling local ownership and drive.
Editorial: Wasteful Disassembly
May 16, 2008
Automakers usually try to find the best way to assemble the cars they build. In a bizarre twist on this theme, Mazda has spent the past 2 years and probably millions of dollars figuring out how to destroy cars.
Fastening Threads: Thinking the Unthinkable
David Archer
April 28, 2008
A good way to approach joint validation is the same way you would balance your family budget.
Editorial: At a Crossroad?
April 25, 2008
At press time, American Axle & Manufacturing Holdings Inc. (Detroit) remains locked in a month-plus long strike with the United Auto Workers union over proposed pay cuts.
Quality in Assembly: Robots Can Help With Test, Inspection Applications
April 21, 2008
Robots can bring the same flexibility, efficiency, accuracy and tirelessness to test and inspection applications as they can to more traditional tasks.
Leading Lean: Measure for Success
April 18, 2008
Make your changes visible. If others can’t see them, they can’t learn from them and won’t follow your lead.
Previous 1 2 … 127 128 129 130 131 132 133 134 135 … 222 223 Next
