Bonding Lines: Phenolics-Oldies but Goodies
Dr. George W. Ritter
September 30, 2008
Phenolic resins have been industrially important since the late 19th century.
Quality in Assembly: Want Fast Improvement? Try a Kaizen Blitz
September 30, 2008
For a kaizen blitz to succeed, the team must have absolute authority to change the process.
Leading Lean: Know the Score and What to Do
September 29, 2008
You can’t manage what you can’t understand. Measurement by itself adds no value.
Editorial: Accidents and Innovation
September 29, 2008
Mistakes are part of learning, beginning with childhood and continuing throughout life-even for a genius.
Fastening Threads: Torque Audits Are a Good Way to Check Joints
David Archer
August 28, 2008
The most common method of checking a bolted joint is generally referred to as a "torque audit," which measures a value know as "residual torque."
Quality in Assembly: How Effective Is Your Assembly System?
August 22, 2008
OEE quantifies how well an assembly system performs relative to its intended capacity.
Assembly in Action: ERP Streamlines Shipbuilding Operations
August 21, 2008
Recently the company found its business expanding to the point where it was having trouble keeping track of costs, inventory and billing.
Assembly in Action: Bearings Ensure Effective Arm Performance
August 21, 2008
The 7-foot, 7-inch arm is attached to the deck of the Lander and equipped with a garden-sized trowel.
Assembly in Action: Taking Advantage of All Three Dimensions
August 21, 2008
The ultimate goal was a fully automated, conveyor-based, continuous-flow pull system capable of ac-commodating the company’s lean manufacturing philosophy.
Assembly in Action: Positioners Cut Final Assembly Times
August 21, 2008
The company designed and built the automated assembly and positioning systems used to attach the wings, and the nose and tail sections to the airplane’s mid fuselage section.
Previous 1 2 … 124 125 126 127 128 129 130 131 132 … 222 223 Next
