Home » Topics » Technologies » Plastics & Metal Welding Assembly
Plastics & Metal Welding Assembly RSS Feed RSS
Robotics: Innovations in Grippers
June 21, 2011
Inspired by nature, engineers are developing new gripper technologies that promise to make robots more flexible.
Leak-Proof Plastics Assembly
May 31, 2011
Several manufacturers consider electromagnetic, or induction, welding a better way to weld highly filled thermoplastics than thermal or friction welding, or using adhesives.
Additive Manufacturing May Lead to New Assembly Paradigm
March 31, 2011
In the future, the “smartest" form of assembly may be no assembly at all. That’s the goal of additive layer manufacturing.
Fastening: Going With the Flow
March 31, 2011
Automakers are often the driving force behind the latest product and process innovations in assembly. Case in point: European automakers have been using flow drilling screws since 1996 to assemble body panels and chassis made of aluminum and thin materials-which continue to gain favor to make cars lighter.
Automating Small-Batch Welding
January 28, 2011
Traditionally, manufacturers have relied on manual welding to assemble high-mix, low-volume products. But, more companies are turning to a new breed of flexible robots, software and controls.
Technologies for Joining and Splicing Wires
September 27, 2010
Whether joining two wires together or attaching multiple wires directly to a terminal or assembly, engineers must choose between resistance welding, soldering and ultrasonic welding.
Welding
Friction Spot Joining Provides Alternative to Resistance Welding for Joining Aluminum
January 28, 2010
A new process, friction spot joining, has been developed to produce lap joints in aluminum sheets.
Troubleshooting the MIG Welding Process
Andy Monk
April 28, 2009
These tips and tricks will help you solve common MIG welding problems.
Plastics Under the Hood
March 30, 2009
Traditionally, using any material other than metal in the engine compartment was unthinkable. But, that old rule of thumb is changing as many automakers and suppliers use plastic to reduce vehicle weight.
Keeping Screws Tight
December 19, 2008
Preventing screws from loosening requires the right combination of thread design, torque specification and fastening tool.
Previous 1 2 … 37 38 39 40 41 42 43 44 45 Next
