Assembly Breaking News IndustriesTechnologiesGreen Manufacturing AssemblyElectronics AssemblyAdhesives & Dispensing Assembly
Reversible Adhesive Aids Disassembly and Recycling
Newcastle University
A new type of reversible adhesive that makes disassembling and recycling electronics much easier. Photo courtesy Newcastle University
May 26, 2026
NEWCASTLE, England—Electrical and chemical engineers at Newcastle University have developed a reversible adhesive that makes disassembling and recycling electronics much easier.
The glue is electrically conductive, so it can be used to assemble electronic components, just like solder. Unlike solder, however, a simple wash with a green solvent like acetone, or using an alkaline solution, enables components to be separated for recycling and reuse.
“This is a ‘one-pot’ glue and is water-based, so it does not emit organic solvent vapors and does not require a hardener, unlike some glues,” says Bassam Aljohani, a Ph.D. student in the school of engineering who is working on the R&D project. “It is also as strong as other water-based glues.
“The glue is made in the same way as a paint, but silver particles are added rather than pigments, and this gives the formulation its electrical properties,” explains Aljohani. “Other conducting glues exist, and many of these also include silver for optimal conductivity, but none can easily be debonded.”
According to Aljohani, reversible adhesive will help address challenges associated with electronic waste. “Electrically conductive adhesives have been around for a long time, and making them reversible provides the solution to a very real problem that urgently needs addressing,” he points out. “Being reversible, our glue [makes it possible to recover and reuse] silver, which is important to keep costs down and the environment clean.”
The adhesive is based on current industrial manufacturing processes used for making paint. And, because it’s developed from cheap materials, it can be scaled up easily.
“It is water-based, so it does not have the volatile organic solvents used in many commercial glues,” claims Aljohani. “But, unlike other water-based adhesives, exposure to humid environments does not cause bond failure. The glue works very well on metal surfaces; it also sticks to other surfaces, such as plastics and printed circuit boards.”
“The electronics industry relies on permanent joining methods, including screws, which can make automated recycling more difficult,” adds Ama Asiedu-Asante, Ph.D., an electrical engineer who worked on the project. “There is now increasing recognition that water-based formulations can support more sustainable electronics, and this [breakthrough] demonstrates how they can deliver both performance and reversibility.”
KEYWORDS: adhesive technology bonding electronics industry recycling sustainability university innovation university research
  • Reversible Adhesive Facilitates Repairs, Recycling
  • robotic disassembly of motherboards and other electronic components
    New Process Automates Electronics Disassembly
    Battery Disassembly Process Improves EV Recycling Efforts
  • Sustainable Manufacturing
  • RecycleMax Inc.
