TechnologiesASSEMBLY Trends
ASSEMBLY Audible
PODCAST | AI in Manufacturing: A Force Multiplier Still Stuck in Pilot Mode
By JJ Moore
robot hand and human hand touching lightbulb
Image courtesy ipopba / Adobe Stock
June 18, 2026
U.S. manufacturers are increasingly turning to artificial intelligence as a way to stay competitive in a rapidly evolving global market.
“I think the key is… looking at AI as a force multiplier,” says Mike Sabin, CEO of Revalize. “How do [you] make the existing team more effective, more productive? It’s not necessarily [about] completely shifting the model.”
Listen to our interview with Mike Sabin!
But while manufacturers see AI as a real solution, most are still struggling to scale those efforts.
Manufacturers are beginning their AI efforts in areas where the value is easier to measure. Predictive maintenance and quality control are leading use cases, in part because they rely on well-defined datasets and offer clear return on investment.
“These are data-rich environments where they can demonstrate ROI,” Sabin says.
But while those applications are a logical starting point, they are not enough on their own.
“Pilot programs are a great way to learn, but totally insufficient,” he adds. “To fully deploy and leverage AI requires changing many things, not just a software installation.”
AI depends on access to consistent, high-quality data across systems. But in many facilities, that data remains fragmented.
“Many manufacturers are lagging because their data still sits in a number of legacy silos,” Sabin says.
AI systems rely on historical data to predict future outcomes. Without reliable, connected data, those predictions become less useful.
“If you’ve got poor data, it’s the old saying: garbage in, garbage out,” Sabin notes.
Unlocking that data requires integration across systems such as ERP and MES, as well as changes to how information flows across the organization.
Complete scaling also requires rethinking the systems that data flows through.
Fully replacing legacy systems is often impractical due to cost and disruption. At the same time, simply layering AI on top of outdated systems can create new problems.
Instead, Sabin says manufacturers should take a hybrid approach: incrementally modernizing systems while introducing AI where it can deliver immediate value.
Ultimately, Sabin says, the companies that succeed will be those that move beyond experimentation and treat AI as a core part of how their operations run: using it not to replace people, but to amplify what they can do.
KEYWORDS: Artificial Intelligence (AI) Industry 5.0 Productivity
Jj moore author
  • manufacturing data
    PODCAST | Why AI in Manufacturing Depends on Fixing Factory Data
  • Female worker engineering staff work checking robot arm in assembly plant with tablet.
    AI in Manufacturing: Reshaping Quality Control and Efficiency
  • GE Appliances
    NIST Launches Center for AI in Manufacturing
  • achieving
  • Kent Manufacturing LLC, a Sur-Seal Co.
    Sur-Seal is a top-tier manufacturer of engineered components, helping customers solve complex sealing, insulation, thermal, and protection challenges. We offer a range of custom die-cut, molded, formed, and extruded parts. We strive to be a leader in our industry by delivering exceptional service and fostering a positive company culture that values the contributions of our employees and partners.
