New Process Assembles Contacts Fast
January 1, 2001
CUDAHY, WI--Handy & Harman Precious Metals Group has introduced a new process for in-die, high-speed fabrication of electrical contacts.
The Consert process starts with specially shaped wire tape clad in precious metal. Supplied in long, continuous coils, the tape consists of a base metal bonded with a precious metal alloy and formed into a T-shaped cross section.
The tape is fed directly into a tooling system developed by Pylon Tool Corp. (Northbrook, IL). In one high-speed step, the tape is cut and inserted into a pierced hole in the contact substrate, where it is securely staked into place to form the electrical contact assembly.
Multiple insertions can be made on the same machine. Insertion speeds are typically 10 to 15 times faster than conventional rivet staking and two to three times faster than in-die contacting.
Approximately 50,000 to 100,000 contacts can be made from a single tape, which can be made in a variety of configurations and shank lengths. The tape is available in all common contact materials, including gold, silver and palladium alloys. There are no significant restrictions on layer thickness or size of the contact. Because of the metallurgical bond between the layer of precious metal and the base material, the edge of the contact won't lift away. Once inserted, the contacts stay reliably in place.
For more information, call Handy & Harman at 800-558-3856.
  • Assembly Innovations: New Process Assembles Flip Chips Faster, Better
    New Process Turns Mixed Plastic Waste Into New Car Parts
  • attaching a plastic cover to a metal housing
    New Process Joins Plastic to Metal
  • Phoenix Contact
    Phoenix Contact produces future-oriented components, systems, and solutions for electrical controls, networking, and automation. With a worldwide network reaching 100+ countries and with over 22,000 employees, Phoenix Contact maintains close relationships with its customers. The company's wide variety of products makes it easy for engineers to implement the latest technology.
  • Phoenix Contact
