Quality in Assembly: Problem-Solving System Helps Cabinet Maker Win
May 20, 2009
A strand of ribbon isn’t much, but for one Michigan assembler, it may just have led to a 2008 Shingo Prize for Operational Excellence.
Assembly In Action: Plastic Welders Take to the Sea
May 20, 2009
To build each hull, Turbotsan’s operators first create a frame of polyethylene pipe that serves as the skeleton for the boat-much like the “ribs” in a traditional wooden hull.
We Fed It: Bowl Feeds Handles for Dental Mirror Assembly
May 20, 2009
Five inches long and 0.5 inch in diameter, the mirror handle was shaped for ergonomics and utility-not for automated assembly.
Automation Profiles: System Wraps, Trims, Welds Car Doors
May 20, 2009
T.A. Systems worked closely with the customer to optimize the product for assembly.
Moving Forward: St. Jude Medical Expands Carolina Assembly Plant
May 20, 2009
Medical device manufacturer builds new plant to meet demand for pacemaker components.
Editorial: Do As I Say...
May 20, 2009
The results are in from the latest National Assessment of Educational Progress.
Leading Lean: A Tool for Lean Thinking
May 20, 2009
A lean tool won’t make you a lean thinker any more than a paintbrush or a sax will make you Rembrandt or John Coltrane.
Process Control for Dispensing Gaskets
Axel VanBriesen
May 20, 2009
Closing the control loop leads to successful automated gasket dispensing.
Fastening Threads: Nine Common Bolting Boo-Boos
David Archer
April 29, 2009
As with most endeavors where success can’t be measured by keeping score, a good job of engineering is often defined by not doing a bad job. In other words, the most direct measurement of successful joint design and assembly is a lack of joint problems. Here’s a brief look at the most common reasons why problems occur during joint design, joint assembly and troubleshooting.
High-Flying Robots
April 29, 2009
Traditionally, aircraft assembly has been a labor-intensive, manual process. But, robots are slowly becoming a key part of military and commercial aircraft production lines as the aerospace industry adopts new materials, grapples with throughput issues, and addresses ergonomic concerns and skilled labor shortages. Within the next three years, demand for robotic equipment will increase dramatically.
Previous 1 2 … 124 125 126 127 128 129 130 131 132 … 286 287 Next
