Test-Centric Assembly
Jacques Hoffmann
April 28, 2009
Engineers should consider the test requirements for a product early in the design of an automated assembly system.
Troubleshooting the MIG Welding Process
Andy Monk
April 28, 2009
These tips and tricks will help you solve common MIG welding problems.
Quality in Assembly: Even Humble Screws Get a Battery of Quality Checks
April 28, 2009
The quality checks start before a single fastener is even produced.
Automation Profiles: Dial Assembles Disposable Dispensers
April 28, 2009
Various sensors ensure that parts are present and correctly oriented. A leak tester checks the final assembly.
Crimp Force Monitoring
Rob Boyd
April 22, 2009
Engineers need to understand how crimp force monitors work to take full advantage of their capabilities.
Assembly in Action: Waterproofing a Space Robot
April 22, 2009
Engineers have had to figure out a way to adequately maintain the station given that the number of supply missions has been considerably reduced following the Space Shuttle Columbia disaster in 2003.
Assembly in Action: Sensors Error-Proof Cap Assembly
April 22, 2009
Recently, MPC upgraded its oil-cap assembly machine by substituting a machine-vision inspection system to take the place of the traditional tool and sensor technology it had been using previously.
Assembly in Action: ‘Milfords' Keep Knives Working
April 22, 2009
On these and several other products, Buck Knives uses no other means of attaching the two pieces together: There is no adhesive, only the two or three rivets inserted and rolled by the Milford riveter.
Assembly in Action: Automated Leak Tester Provides Precision, Traceability
April 22, 2009
Among other improvements, Eaton wanted to incorporate a real-time test data system that could be fully integrated with its plant-control network to facilitate government tracking and record keeping.
Assembly in Action: Rivets Ensure Quality Seat Assembly
April 22, 2009
The placing heads then close horizontally, simultaneously inserting the rivets and brackets into the holes of the harp. Afterward, they extract the stems and return to a home position.
Previous 1 2 … 125 126 127 128 129 130 131 132 133 … 286 287 Next
