Assembly in Action: Robots Facilitate Connector Manufacture
January 31, 2007
Modern construction techniques increasingly call for factory-assembled roof and flooring modules to minimize “on-site” building times and the need for skilled carpenters. Responding to this demand, Simpson Strong-Tie Co. (Pleasanton, CA) has developed a line of timber-to-timber and timber-to-masonry steel connectors.
Assembly in Action: BAE Upgrades Process Software to Keep Pace with F-35 Fighter
January 31, 2007
The ongoing F-35 Lightning II Joint Strike Fighter (JSF) program is unprecedented not just in the complexity of the aircraft itself, but also in the complexity of its development program.
Assembly in Action: Towline Improves Tractor Assembly
January 31, 2007
At its manufacturing facility in Fargo, ND, Case New Holland (Amsterdam, Netherlands) performs final assembly of its heavy-duty, articulated agricultural tractors. Weighing 60,000 pounds, the machines have long presented a material handling challenge as well as a challenge for safe, efficient assembly.
Leading Lean: From Dabbling to Commitment
January 31, 2007
Get a purpose, take away the crutches, ask how well you’re doing, and you can move from dabbling to commitment!
Assembly of Automotive Interior Components
January 31, 2007
Believe it or not, cup holders were unheard of in automobiles 25 years ago. But not anymore. Americans are spending more and more time inside their cars, and the market is responding accordingly. Today, interiors are ground zero for automakers and suppliers.
Bonding Lines: Cyanoacrylates for Assembly
Dr. George W. Ritter
January 30, 2007
Wouldn’t an adhesive that bonds to everything, cures instantly, survives temperature extremes and never breaks be a super glue? Well, almost.
Fasteners for Automation
January 30, 2007
The right fastener can mean the difference between an automated screwdriver that operates smoothly and one that jams constantly.
Conveyors and Lean
Adam Cort
January 26, 2007
Despite the popularity of manual work cells and “less is more” thinking, powered conveyors can still play a role in a lean manufacturing environment.
Assembly Innovations: Capaciflectors Guide Robots to Bolt Heads
January 1, 2007
Vision systems are excellent for guiding robots. However, for some applications, such as tightening bolts, a vision system is of little help, because the end-effector and tool are so close to the fastener they block the camera’s view.
Assembly Innovations: Device Monitors Curing of Epoxies
January 1, 2007
To get bonded assemblies out the door as quickly as possible, researchers at NASA’s Langley Research Center have developed a noninvasive system for monitoring the cure status of epoxies and other resins.
Previous 1 2 … 164 165 166 167 168 169 170 171 172 … 286 287 Next
