Assembly In Action: Semiconductor Platform Assembles Flip Chips
September 30, 2011
In early 2010, Draper Laboratory was in need of a semiconductor platform that met two criteria. First, it had to perform flip chip assembly, in which microelectromechanical systems are connected to circuitry with solder bumps that have been deposited onto the chip pads. Second, the platform had to be adaptable, because Draper develops products for a wide range of applications requiring the latest technology.
Assembly In Action: Insertion Machine Keeps Parts Supplier in Touch With Customers' Needs
September 30, 2011
SMB Schnekenburger GmbH provides assembly-ready parts made of thin sheet metal to electronics firms, equipment manufacturers, and companies in ventilation and medical technology. For the past several years, SMB has faced increased competition from suppliers in low-wage countries. This situation has forced SMB to make parts more cost-effectively without lessening fastener-insertion accuracy.
Wire Processing: Porosity Sealants for Wire Harnesses
September 29, 2011
All day long, wire harnesses are sealed against porosity at nine Magna-Tech Manufacturing facilities located throughout North America. These wire harnesses are of different lengths, contain wire of different thicknesses, and are made by Tier 1 suppliers such as Delphi, ATPI, Siemens, Group Dekko and Federal Mogul.
Robotics: Two Arms are Better Than One
September 29, 2011
When preparing parts for assembly, automakers can always use an extra hand or two. One automaker has found those hands at the end of a dual-arm robot. For the past four years, the automaker has used the dual-arm robot to shorten the cycle time to treat the front and back surfaces of a suspension component.
Shipulski on Design: How to Make Your Green Programs Actionable
Dr. Mike Shipulski
September 28, 2011
It’s time to figure out what we can change to be green.
Micro Welding Conductive Materials
Geoff Shannon
September 28, 2011
Green lasers are a viable method for welding thin copper parts in high-volume applications.
The Editorial: Feds Strike the Wrong Chord
September 28, 2011
Although Memphis ranks third in the United States in violent crime and second in property crime, the federal government is seemingly more worried about the wood Gibson guitars uses in its products.
Wire Processing: Data-Centric Tools Reduce Design Costs
John Wilson
September 28, 2011
New software enables synchronized design data to flow seamlessly through domains and across organizations.
2011 Assembly Plant of the Year: Philips Doesn't Rest on Lean Laurels
September 26, 2011
Philips' New Kensington, PA, assembly plant was designed from the ground up with three things in mind: people, lean manufacturing and the environment.
Wire Processing: Wire Insulation Goes Green
September 26, 2011
Whether it's aluminum or copper wire, thick or thin cable, insulation is essential. Without it, heat would build up and cause shorts, sparks and flames.
Previous 1 2 … 86 87 88 89 90 91 92 93 94 … 286 287 Next
