Home » Topics » Technologies
Technologies
Technologies RSS Feed RSS
troubleshooting screwdriving
Troubleshooting the Screwdriving Process
August 1, 2024
Engineers need to understand how multiple variables can affect fastening applications.
WEISS North America's DR series delta robot
See It at the Show
New Delta Robot Designed for High-Speed Applications
July 31, 2024
Available with two to five axes of motion, the DR series delta robots are designed for high-speed assembly and handling—especially for automated applications in the packaging and electronics industries.
cobot for machine tending
Cobot Automates Machine Tending
Colleen Soine
July 30, 2024
A safe, flexible gripper enables the cobot to handle a wide variety of parts.
hot forming
Aerospace Assembler Forms Titanium Parts
July 29, 2024
The hot-forming process creates complex shapes without fracturing, spring-back or residual stress.
Daniels' PT-150HA manual wire crimp pull tester
Wire Processing Products
Pull-Tester Checks Crimp Strength
July 26, 2024
The PT-150HA manual wire crimp pull tester is ideal for testing crimp strength on wires up to size 10 for Mil-Spec applications and size 4 AWG for commercial and automotive applications.
automotive wire harness
Wire Processing
Smart Glasses Aid Inspection of Automotive Wire Harnesses
Mingzhe Yuan Ph.D.
July 25, 2024
AI-based vision system ensures that relays and other components are installed correctly.
robotic gripper
Assembly Lines
New Technique Helps Robots Grasp the Unpredictable
July 24, 2024
The Grasping Neural Process trains robots to infer invisible physical properties from a history of attempted grasps, and then use the inferred properties to guess which grasps would work well in the future.
new system for condition monitoring and predictive maintenance
Assembly Lines
Intelligent Sensors Use AI for Predictive Maintenance
July 23, 2024
Engineers at the Fraunhofer Institute for Photonic Microsystems (IPMS) here have developed a new system that combines sensor technology, data acquisition and AI-based data evaluation for condition monitoring and predictive maintenance.
Smart Manufacturing 5.0
Assembly Lines
‘Smart Manufacturing 5.0’ Focuses on Human-Centric Factories
July 22, 2024
According to Info-Tech, companies should adopt Smart Manufacturing 5.0, which combines the innovations of Industry 4.0 with a focus on human-centric, resilient and sustainable practices.
artificial intelligence
Assembly Lines
NAM Report Touts Vast Potential of AI for Manufacturers
July 19, 2024
WASHINGTON —The National Association of Manufacturers has released a report on artificial intelligence that examines why the technology is important and explains how leading companies are using it to improve productivity.
Previous 1 2 … 42 43 44 45 46 47 48 49 50 … 54 55 Next
