Home » Topics » Technologies » Test and Inspection Assembly
Test and Inspection Assembly RSS Feed RSS
2011 Assembly Plant of the Year: Philips Doesn't Rest on Lean Laurels
September 26, 2011
Philips' New Kensington, PA, assembly plant was designed from the ground up with three things in mind: people, lean manufacturing and the environment.
Quality Assurance: Creating a Chopper
Gregory Richards
August 24, 2011
A state-of-the-art portable measurement arm inspires-and helps create-a custom chopper from Paul Jr. Designs.
Wire Processing: Passing the Test
June 21, 2011
Once a wire harness has been assembled, it must be tested for safety, continuity and functionality.
Leak-Proof Plastics Assembly
May 31, 2011
Several manufacturers consider electromagnetic, or induction, welding a better way to weld highly filled thermoplastics than thermal or friction welding, or using adhesives.
Leak Testing Aerospace Parts
April 27, 2011
Fuel systems, engines, landing gear, ventilation systems and other aerospace devices that rely on numerous tanks, pumps, actuators, lines and fittings must be tested for tightness during both assembly and maintenance applications.
Machine Vision: Troubleshooting Vision Systems
December 22, 2010
If a vision system isn’t working optimally, engineers should check for mechanical, electrical and optical problems.
A Sunny Disposition
Adam Cort
December 18, 2008
To help curb costs, solar panel manufacturers are increasingly employing robotics as much as possible.
Robotics
Machine Vision Aids Robotic Assembly
Vision-guided robotics can help manufacturers improve accuracy, increase flexibility and decrease fixturing costs in automated assembly systems.
August 23, 2007
Fixturing for Leak Testing
Adam Cort
December 1, 2006
Every leak test system has one thing in common: The product being tested must be effectively sealed and fixtured.
Machine Vision Dos and Don'ts
October 6, 2005
For some people, learning how to ride a bike or swim comes naturally. For others, it's one of the hardest things they ever do. Implementing machine vision technology can often be a similarly easy or difficult scenario.
Previous 1 2 … 37 38 39 40 41 42 43 44 45 Next
