Home » Topics » Technologies » Test and Inspection Assembly
Test and Inspection Assembly RSS Feed RSS
Free Webinar Covers Rotary Torque Sensors
July 19, 2012
IRVINE, CA—Futek will present a free webinar July 25 that will discuss how to use and specify rotary torque sensors.
A New Standard for Harness Assembly
July 2, 2012
Myriad changes are expected in the soon-to-be-released third revision of the IPC-WHMA-A-620 standard for wire harness assemblies.
Assessing Crimp Quality
July 2, 2012
 These tests make sure that each crimp meets—or exceeds—performance specifications.
Ergonomics Lifts Fabricator’s Products and Profits
July 2, 2012
Ergonomics is good for plant workers as well as plant profitability. A good example of this can be found at the Westbrooke, ME, plant of SIGCO Inc., a glass and architectural metal fabricator and distributor.
Assembly in Action: Sheet Metal Shop Takes One and Done Approach to Hardware Insertion
June 1, 2012
Based in Abbotsford, BC, Overlanders Manufacturing is a large supplier of precision sheet metal and tubular products, including parts for the electronics industry. Many of these parts must be plated prior to fastener insertion.
JV to Build Automated Leak Testing Equipment
May 25, 2012
HOUSTON—USON has signed a joint-venture agreement with Innovative Products and Equipment. The new company will offer automated leak testing systems.
Free Webinar Covers New Code-Reading Technology
May 16, 2012
BOSTON—Cognex Corp. is hosting a free webinar May 22 to present its new technology, called Hotbars, that promises to make reading bar codes faster and more accurate.
Leak Testing Large Castings
May 1, 2012
Porosity and sealing affect engine blocks, wheels and other big auto parts.
Researchers Invent New Automated Inspection System
April 30, 2012
MAGDEBURG, Germany—Researchers at the Fraunhofer Institute for Factory Operation and Automation IFF have come up with an automated visual inspection system that is reliable and economic even for one-off production runs.
Quality Initiative Transforms Chrysler Belvidere
April 26, 2012
Chrysler Group LLC is betting big on its new Dodge Dart compact sedan, which hits dealer showrooms in June.
Previous 1 2 … 37 38 39 40 41 42 43 44 45 Next
