Home » Topics » Technologies » Plastics & Metal Welding Assembly
Plastics & Metal Welding Assembly RSS Feed RSS
Infrared Cameras Improve Quality of Plastic Welding Process
December 1, 2016
For more than 30 years, manufacturers have used infrared welding (IW) to assemble plastic components that are large, made of challenging materials or have high strength and hermetic requirements.
New Machine Rolls, Welds Stainless Steel Drums for Laundry Appliances
November 15, 2016
COLDWATER, OH—Systems integrator Coldwater Machine Co. has developed a new machine that automatically rolls and welds stainless steel drums and baskets for washers and dryers.
Truck-body welding gets lift from tandem robots
October 1, 2016
Manufacturers with long histories and famous founders (e.g., John Deere, Henry Ford, F.L. Maytag) are numerous throughout the world.
New Technology for Robotic Welding
A new generation of robots is helping assem-blers weld parts better, faster and more cost-effectively.
September 8, 2016
Welding of one sort or another has been the No. 1 application for industrial robots almost since the technology was invented.
Welding Incompatible Thermoplastics
Incompatible thermoplastic polymers can be welded by using polymer blends that are compatible with both components.
September 8, 2016
Ideally, every component in a plastic assembly would be made from the same material. However, cost, functional and aesthetic requirements often dictate that a mix of materials be used.
agave bioplastic
Ford, Jose Cuervo Team up to Make Car Parts From Agave
August 8, 2016
DEARBORN, MI—Ford Motor Co. is teaming up with Jose Cuervo to explore the use of the tequila producer’s agave plant byproduct to develop more sustainable bioplastics to employ in Ford vehicles. Ford and Jose Cuervo are testing the bioplastic for use in vehicle interior and exterior components, such as wiring harnesses, HVAC units and storage bins.
Lasers Will Play Greater Role in Auto Body Assembly Lines
August 8, 2016
TRAVERSE CITY, MI—Robotic laser welding will play a greater role in body-in-white assembly lines, as automakers increase their use of lightweight materials, according to Peter Busuttil, director of technology for KUKA Systems North America.
Scientist Figures Out How to Make Plastic 100 Percent Biodegradable
July 5, 2016
MIAMI—A chemist has developed a way to make all fossil-fuel based plastics 100 percent biodegradable.
Additive Manufacturing and End Of Arm Tooling
Innovative 3D-printed end-of-arm tooling enables systems integrator to lighten the load on a robotic packaging line.
Kip Hanson
July 1, 2016
Necessity is the mother of invention, or so the proverb goes. Such was the case recently at The Langen Group, a manufacturer of automated packaging equipment in Mississauga, ON.
New Plastics for 3D Printing
Engineers have more material options available than ever
July 1, 2016
What do rockets, ski boots and submarines have in common? They can all be assembled with plastic-printed components.
Previous 1 2 … 21 22 23 24 25 26 27 28 29 … 44 45 Next
