Home » Topics » Technologies » Wire Processing Assembly
Wire Processing Assembly RSS Feed RSS
Designing an Ergonomic Cable-tie Tool
January 3, 2013
Lots of tool makers say their products are ergonomic. Few of them actually prove it.
Wire Processing
Should You Invest in Fully Automatic Stripping and Crimping Machines?
if you need to produce thousands of identical crimped wires in a shift, you need a fully automatic cutting, stripping and crimping system.
January 3, 2013
New equipment addresses changeover and repeatability issues.
IPC, WHMA Release Revise Wire Harness Standard
November 5, 2012
BANNOCKBURN, IL—Significant technical updates, greater ease-of-use and compatibility with other key assembly standards are among the many changes engineers will find in the newly released B revision of IPC/WHMA-A-620, Requirements and Acceptance for Cable and Wire Harness Assemblies.
Heat Shrink Tubing
October 1, 2012
Made of thermoplastic or elastomeric material, this tubing provides an extra layer of protection to wire harnesses.
Connectors for Energy-Efficient Lighting
Ronald Weber
October 1, 2012
The right connector can make a big difference in the performance of LED-based lighting.
Automating Control Panel Assembly
Patrick Boyer
October 1, 2012
New automation technologies can save control panel manufacturers thousands in assembly costs
Harness Shop Expands
September 26, 2012
PORTLAND, OR—Wire harness manufacturer AmFor Electronics has added 10,000 square feet space to its assembly plant here.
Big Three Explore Aluminum Wiring Pros and Cons
July 2, 2012
Engineers must address six challenges before aluminum use in vehicles will surpass copper.
A New Standard for Harness Assembly
July 2, 2012
Myriad changes are expected in the soon-to-be-released third revision of the IPC-WHMA-A-620 standard for wire harness assemblies.
Assessing Crimp Quality
July 2, 2012
 These tests make sure that each crimp meets—or exceeds—performance specifications.
Previous 1 2 … 22 23 24 25 26 27 28 29 30 Next
