TechnologiesNew ProductsTest and Inspection Assembly
New & Noteworthy
High-Speed Vacuum Pump
HiCube Neo vacuum pumping station
Image courtesy of Pfeiffer Vacuum
May 15, 2024
With pumping speeds ranging from 80 to 800 liters per second, the HiCube Neo vacuum pumping station is ideal for demanding high vacuum and ultra-high vacuum applications. The station can be prepared for wide-ranging applications with an array of different backing pumps, such as diaphragm, rotary vane, scroll and multi-stage Roots pumps. Typical uses range from analyzing gases and calibrating vacuum gauges to pumping down cryostats and use in vacuum furnaces.
Features include a 7-inch touch screen, remote control via a web server, and detailed data recording. Its open design facilitates maintenance and allows easier access to the components. The backing pump’s energy-efficient standby mode also reduces energy use and cuts operating costs.
Pfeiffer Vacuum
pfeiffer-vacuum.com
KEYWORDS: leak testing vacuum pump
August 14, 2025
    How To: Choose A Vacuum Pump
  • Vacuum Pump Aids Particle Physics Research at CERN
  • Dreame 12-23
    Dreame Tech's Smart Factory Produces Ultra-High-Speed Vacuum Motors
  • COVAL Vacuum Technology Inc.
    COVAL Vacuum Technology Inc. specializes in the manufacturing and distribution of vacuum components and complete EOAT for the automation industry. With more than 35 years of experience, COVAL is a force for permanent innovation in the field of vacuum technology. Our product line includes grippers, suction cups, vacuum pumps, vacuum switches, spring compensators and peripheral devices.
