Home » Topics » Industries » Automotive Assembly
Automotive Assembly RSS Feed RSS
Outsourcing's Alphabet Soup
February 1, 2003
As outsourcing continues to evolve, it’s becoming more complicated. Indeed, depending on what acronym you use, outsourcing can mean different things to different people.
pcv valve
Flow Testing Instruments Help Automotive Supplier Meet Quality Specs
September 1, 2002
Flow testing instruments help automotive supplier satisfy stringent specifications for PCV valves.
Magnetic Pulse Welding Joins Parts Without Heat
August 1, 2002
The cold-welding process can join dissimilar materials, such as aluminum to steel, within a short cycle time.
Peterbilt manufacturing
Anaerobic Sealing Compound Keeps Big Rigs on the Road
August 1, 2002
Peterbilt Motors Co. (Denton, TX), a division of Paccar Inc., manufactures commercial trucks and offers a broad range of services for over-the-road, construction, municipal and medium-duty truck markets
How to Clinch Sheet Metal
Clinching is a cost-effective method for joining sheet metal parts.
Adam Cort
May 1, 2002
Not every assembly task involving sheet metal is amenable to fasteners or welding. Clinching requires neither and can be a cost-effective method of joining sheet metal parts.
rivet nut
Fastener Handling System Saves Time When Installing Rivet Nuts
May 1, 2002
Traditionally, assemblers at General Motors installed Rivnut fasteners into vehicle bodies with a handheld power screwdriver. A new fastener handling system made the process more efficient.
bleichert conveyor
Conveyor Handles Engines and IPs
Adam Cort
April 1, 2002
Ford Motor Co.’s Wayne, MI, assembly plant is a facility where new, productivity-enhancing technologies are often put to work first.
Ford Shifts Flexible Assembly Into High Gear
Automotive Industry
Force-Controlled Assembly of Automotive Components Using Robots
With force sensors and vision systems, robots can automate assembly of automotive transmissions and clutches.
Valerie Bolhouse
January 1, 2002
Assembling automotive powertrain parts, such as clutches, requires precise alignment of gear meshing and other critical components.
The Pros and Cons of Automated Welding
October 1, 2001
Automated welding can provide large gains in productivity and profitability - in the right applications.
Welding: Arc Stud Welding
Blake Hobson
July 1, 2001
Stud welding is a process by which a metal stud is joined to a metal workpiece by heating both parts with an arc of electricity. Compared with other welding and fastening processes, stud welding offers faster assembly with fewer steps. This article explains how this process can be used for profitable and reliable assembly.
Previous 1 2 … 314 315 316 317 318 319 320 321 322 Next
