Home » Topics » Industries » Automotive Assembly
Automotive Assembly RSS Feed RSS
Ford Shifts Flexible Assembly Into High Gear
Automotive Industry
Force-Controlled Assembly of Automotive Components Using Robots
With force sensors and vision systems, robots can automate assembly of automotive transmissions and clutches.
Valerie Bolhouse
January 1, 2002
Assembling automotive powertrain parts, such as clutches, requires precise alignment of gear meshing and other critical components.
The Pros and Cons of Automated Welding
October 1, 2001
Automated welding can provide large gains in productivity and profitability - in the right applications.
Welding: Arc Stud Welding
Blake Hobson
July 1, 2001
Stud welding is a process by which a metal stud is joined to a metal workpiece by heating both parts with an arc of electricity. Compared with other welding and fastening processes, stud welding offers faster assembly with fewer steps. This article explains how this process can be used for profitable and reliable assembly.
Assembly Handbook: Blind Riveting
June 1, 2001
Whenever access is limited, blind rivets offer assemblers a unique way to see their way past fastening challenges. This article explains the advantages and limitations of blind rivets, and it reviews the various options for fasteners and installation equipment.
liquid gaskets
Adhesive Bonding
How to Use Formed-in-Place Gaskets
Compared with solid gaskets, formed-in-place gaskets have many advantages.
April 1, 2001
Compared with die-cut or molded gaskets, liquid gaskets have many design advantages. This article reviews the applications for these materials and tells how best to dispense them.
torque tester
Fastening: How Tight Is Tight?
April 1, 2001
How you measure torque can affect your perception of how well your fastening tools perform. This article reviews methods for measuring the torque produced by a tool before, during and after fastening.
Capital Equipment Justification
Diane Hallum
March 1, 2001
The product has been designed, the assembly process laid out and the appropriate technologies selected. Now all you have to do is pitch the project to the person who signs the checks.
Assembly Automation
Process Planning Is Critical to Success of Assembly Automation Projects
March 1, 2001
Basic questions about the product have to be addressed before requests for quotations (RFQs) are issued for an assembly project.
Automotive Industry
Nylon Manifold Debuts on Light-Truck Engine
Plastic component helps Ford reduce vehicle weight.
March 1, 2001
North America's first multishell, vibration-welded intake manifold debuted on Ford's 5.4-liter, two-valve engines on the 1999 Ford F-series 150 and 250 light trucks, Expeditions and Lincoln Navigators. This manifold also marks the first use of Zytel welding-enhanced PA 6,6 nylon resin.
How to Evaluate Suppliers
March 1, 2001
Supplier evaluation is not an easy process. Many different formulas and techniques can be used. One effective method assigns suppliers to four basic categories based upon their level of performance in key areas, such as delivery, quality and responsiveness.
Previous 1 2 … 316 317 318 319 320 321 322 323 324 Next
