Assembly Breaking News TechnologiesWire Processing Assembly
Carbon Nanotube Conductivity Breakthrough Rivals Aluminum and Copper
IDMEA Materials Institute
A new manufacturing process enables carbon nanotubes to conduct electricity comparable to aluminum and copper. Illustration courtesy IDMEA Materials Institute
April 6, 2026
GETAFE, Spain—Engineers at the IMDEA Materials Institute here have developed a manufacturing process that enables carbon nanotubes (CNTs) to conduct electricity comparable to aluminum and copper. They claim the breakthrough could be used in next-generation electric vehicles and other applications that require lightweight, high-strength wiring.
CNTs have long been considered to be ideal building blocks for electrical conductors, because of their unique combination of low density, thermal dynamics and mechanical properties. However, they typically have not provided enough conductivity to rival traditional materials.
“This is the first time that researchers have produced results with CNT fibers demonstrating sufficient performance in this regard to offer a realistic industrial alternative to traditional conductive materials,” says Juan José Vilatela, Ph.D., head of the multifunctional nanocomposites group at IMDEA. He worked on the R&D project along with scientists at the Technical University of Madrid and the University of Zaragoza.
Vilatela and his colleagues were able to produce gas-phase intercalated CNT fibers with room-temperature conductivity as high as 24.5 MS/m (MegaSiemens per meter), nearly half that of copper, but six times lighter.
“Given this substantial weight advantage, these results demonstrate electrical conductors that combine not only a significantly improved weight-to-performance ratio, but also absolute conductivity levels that meet industrial requirements,” explains Vilatela.
According to Vilatela, tetrachloroaluminate (AlCl4) was used as a dopant. By retaining the original structure of the CNT bundles, the doping process increases conductivity while preserving their exceptional mechanical properties.
By doping the highly aligned CNT fibers with AlCl4, the engineers were able to achieve a more than 17-fold increase in electrical conductivity. “This resulted in a mean specific conductivity in excess of that of copper, with a highest measured value above that of aluminum,” claims Vilatela.
“This is particularly significant for the electrification of transport, be it EVs, drones or aircraft, which require large numbers of conductors at the lowest possible weight,” adds Vilatela. “It also holds promise for overhead power cables, which are often limited by their own weight.”
KEYWORDS: carbon materials electric vehicles lightweight materials lightweighting wire harness design
    New Aluminum-to-Copper Bonding Process Joins EV Bus Bars
    New Process Improves Copper Wire Conductivity
  • Can Carbon Nanotubes Replace Copper?
  • assembly june 2019
    ASSEMBLY June 2019 Issue
