Home » Topics » Technologies
Technologies
Technologies RSS Feed RSS
VTMF Series rotary indexing table and servo trunnion
New Technology for Motion Control
New products include a rotary indexing table and a compact electric linear actuator.
April 6, 2026
Here’s a look at some of the latest motion control devices.
IDMEA Materials Institute
Carbon Nanotube Conductivity Breakthrough Rivals Aluminum and Copper
April 6, 2026
GETAFE, Spain—A new manufacturing process enables carbon nanotubes to conduct electricity comparable to aluminum and copper.
humanoid robots
Assembly Lines
Humanoid Robot Market to Grow Quickly Over the Next Decade
April 2, 2026
CAMBRIDGE, England—The humanoid robot industry is entering an early commercialization phase, with adoption expected to scale first in industrial environments.
Sumitomo Electric Industries Ltd.
Nature Inspires Heat-Resistant Wiring Insulation
April 1, 2026
TOKYO—Sumitomo Electric Industries recently developed biomass electrical wire that uses insulation material derived from discarded scallop shells.
NeurOSmart technology platform
Assembly Lines
Sensor System Automatically Monitors Human-Machine Interaction
March 31, 2026
ITZEHOE, Germany—Engineers at the Fraunhofer Institute for Silicon Technology recently developed a system that enables close collaboration between humans and robots.
testing a FIAT vehicle
Can AI Predict Loose Bolts in Automotive Assemblies?
Researchers are using artificial intelligence to examine the relationship between torque and tension, and more importantly, predict how and if bolted joints will fail.
March 30, 2026
This approach can be used to predict the mechanism of self-loosening of bolted joints without additional tests, and it is possible to make predictions with very low error rates using AI, which promises to reduce the costs associated with testing new bolted joint designs.
Meditec F-MAP workstation
Standardized Assembly Cells Save Time
March 27, 2026
The Meditec series from PIA Automation includes cells for manual, semiautomatic and fully automatic assembly.
Subaru auto assembly plant
Subaru Saves Time With PDM Software
Software leverages AI to aggregate, analyze and extract design data to help engineers create better products.
March 26, 2026
Following the introduction of CADDi, Subaru succeeded in reducing the time spent on drawing searches by several hundred hours per month.
assembling wire harnesses
Training Aids Management at Harness Assembler
Tennessee MEP center teaches leadership skills to supervisors at harness assembly startup.
March 25, 2026
The MEP is a program administered by the National Institute of Standards and Technology. The program’s mission is to strengthen and empower small and medium-sized U.S. manufacturers.
manufacturing production
Measuring What Matters: An Engineer’s Guide to Manufacturing KPIs
The right key performance indicators can help engineers improve the performance of their assembly lines.
Herman Tang Ph.D.
March 24, 2026
For engineers and operations managers seeking to improve production performance, selecting the right throughput metrics is critical. This article outlines practical measurement approaches to help monitor, diagnose and improve your manufacturing operations.
Previous 1 2 3 4 5 6 7 8 9 … 54 55 Next
