Home » Topics » Industries
Industries RSS Feed RSS
FasteningJoining_FT
Threaded Fastener Technologies for Thin Metal Appliance Assemblies
Dozens of types and thousands of variations of self-clinching fasteners have been engineered over the years—and more are always on the horizon.
January 1, 2015
Every decision involving fastening and joining can impact the early stages of appliance design, affect the assembly process down the line, and influence the integrity and performance of appliances in service.
Can Quality Be Saved?
Jim Smith Ph.D. ABD
November 24, 2014
While manufacturers agree that the quality revolution that began in the 1980s is a good thing, quality does not seem to have improved as a result.
Four Reasons to Replace a Reed Switch with an MR Sensor in Appliances
As sensor manufacturers continue to advance MR sensor technologies, designers will have one more sensor technology in their arsenal.
October 1, 2014
Design engineers have used reed switches in low-power, battery-operated applications for four key reasons.
MicroGroove_FT
Smaller Diameter-Copper Tubes Support Manufacturing and Design
A report from the 2014 Purdue Conference
September 26, 2014
Research often leads to improvements in manufacturing and product development; and, conversely, experiences with manufacturing often pinpoint new topics for worthwhile research
Reduce_Aerodynamic_Noise_FT
Reduce Aerodynamic Noise
Learn more about the development of new methodologies for the reduction of aerodynamic noise in fans and blowers.
May 1, 2014
Aerodynamic noise is a rising source of concern for fans and blowers manufacturers across all industries, from domestic appliances and equipment to high speed cooling fans in IT and telecoms equipment.
BransonMetalWeld
WEB EXCLUSIVE
Myriad Advantages and Applications of Ultrasonic Metal Welding
April 21, 2014
In the continuing evolution within the family of ultrasonic welding and complementary expanding of appliance needs, ultrasonic metal welding as a solution encompasses superior performance, improved throughput and reduced maintenance.
MakingIt_FT
Making It
Compression Molding
ChrisLefteri_200
Chris Lefteri
March 3, 2014
This process can be pressed into service for forming several different materials.
deprag_FT
The Turbine: The Air Motor Packing Maximum Efficiency
Double engine output while reducing air consumption.
January 3, 2014
What happens when the power from your drive unit simply isn’t enough? When the motor for your robot-controlled plant has to supply maximum power yet has to be physically very small?
EC Motors
EC Motors, Explained
EC motors can make your life easy.
November 1, 2013
It’s no secret that government regulations and energy incentives are forcing manufacturers to create or redesign products to meet more demanding energy restrictions.
Sonoco
IAM 2013
Think Inside the Box: Design for Manufacturing and Assembly
DFMA and the concept of reducing total part count will naturally spread across the organization saving time, money, materials and headaches.
October 25, 2013
An important part of being an engineer is the ability to design products such that they can be manufactured economically with existing technologies in an environmentally conscious way.
Previous 1 2 … 146 147 148 149 150 151 152 153 154 … 158 159 Next
