Home » Topics » Manufacturing Industry Top Stories
Manufacturing Industry Top Stories RSS Feed RSS
Tape for Wire Harnesses
Tapes are a cost-effective method for protecting and bundling wire harnesses
Zoe Leduc
January 15, 2019
In a single year, millions of cars are manufactured worldwide. While the styles, parts and features may vary, every vehicle requires a wire harness. The harness connects the wiring throughout the vehicle, powering everything from power steering and headlights to in-dash displays and heated seats.
Harmonizing global standards for wire management products will increase innovation and reduce costs
Harmonizing Global Standards for Wire Management Products Will Increase Innovation and Reduce Costs
January 14, 2019
Standards form a basis for product development by establishing consistent protocols that can be universally understood and adopted.
Advances in Color Vision Inspection
Color cameras are becoming more affordable and less complex.
January 9, 2019
Once upon a time, color vision technology was limited to large manufacturers with big budgets and lots of in-house technical expertise. But, recent advancements in cameras, lighting and software have made color vision more affordable, less complex and easier to use on assembly lines.
Minimizing Waste in the Dispensing Process
Automation can help cut costs and improve operating efficiency.
January 8, 2019
Eliminating waste is a key part of lean manufacturing initiatives. It's also important when it comes to using adhesive.
Hot Upset Riveting
Hot Upset Riveting
Hot upset riveting combines electrical current with pressure and time to compress and expand a boss or rivet to a desired diameter and shape
Jacob Sponsler
January 7, 2019
Hot upset riveting is a permanent forming and fastening process that uses precision heat and pressure to form hardened workpieces. This process achieves maximum hole-fill, creating a robust joint. Depending on the part requirements, the result can be a fixed or movable joint assembly.
New Standard for Biocompatibility Testing
Revised in August 2018, the ISO 10993-1:2018 standard covers biological evaluation and testing of medical devices.
January 4, 2019
On the assembly line, every medical device is thoroughly checked for quality and functionality. Are all the parts present? Is the needle sharp? Does the device leak? Does air flow where, when and how it’s supposed to? Do triggers and control knobs function correctly? Does the touch screen work?
How Ford's Willow Run Assembly Plant Helped Win World War II
The Willow Run bomber plant made aviation, industrial and social history—along with new B-24s by the hour.
Tim Trainor
January 3, 2019
President Roosevelt stunned millions of listeners when he announced during a May 26, 1940, fireside chat that government must "harness the efficient machinery of America's manufacturers" to produce 50,000 combat aircraft over the next 12 months to confront the "approaching storm" of global war.
New Applications for High-Strength Tapes
Acrylic foam and glazing tapes can often replace fasteners or liquid adhesive in many applications
John Merchant
December 13, 2018
Manufacturers today are trapped in a perennial race to get products assembled and out the door in less time and at lower cost while maintaining high quality. They must also adjust to constant change in the materials they use.
Grippers for Large Parts
Bulkier payloads are spurring demand for heavy-duty grippers.
December 11, 2018
Today, robots are capable of handling much larger and heavier payloads than in the past. Those applications require robust grippers that are up to the task.
Lean Culture Drives Continuous Improvement
Leadership engagement is key to changing employee behavior.
December 10, 2018
When lean tools are used effectively every day, manufacturers eventually arrive at a destination: lean culture. All the continuous improvement efforts along the way will drive a cyclical culture that's sustainable.
Previous 1 2 … 43 44 45 46 47 48 49 50 51 … 80 81 Next
